DvbWorld DVB-S2 HD 2104 USB BOX | SatelliteGuys.US
As an avid TSReader user, I would not purchase it unless it was supported by TSReader. I use the Technotrend S2-3200 with great results (PCI Card, not USB)
I have essentially this unit:
DVB
except it says NEXTORM on the top.
I did the upgrade here:
index
however, I can't seem to get DVB-S2, MPEG-4, 8PSK, or H.264 with the update.
The DVB-S appears to be a good unit for 422 and HD so I think the DVB-S2 should be great.
1) What is the cost of this unit?
2) Is it available from one of the SatelliteGuys sponsors?
1. It is $105 Canadian
2. It is private seller
After some research I already found answer to one of my original questions: turbo encoding is used exclusively by Dish so this receiver will be good for me (FTA).
I am still undecided and I am not sure if I will buy it.
It is very little information about supported by this receiver software (I am software nerd)
Weak response from SatelliteGuys fellows suggests that it is not popular receiver.
9999 thank you for sharing your experiences with the younger sibling of this box.
--- Jan
I bougth it. Received in Brazil in seven days.
The software in the 3.5 CD is useless.
I downloaded the July2008 Version ( UNABLE TO PUT LINK)
[FONT=Arial, Helvetica, sans-serif]1.Add a function to select decoders.
2.Fixed the bugs that fail to scan high symbol rate(30Msps) DVB-S2 channels.
3.Always start IP first,then start default TV.
4.Support AAC decoder
[/FONT]
that works, at least to see HDTV Brazilian channels from the StarOne C2. There are only two DVB-S2 HD channels and eleven DVB-S SD channels below:
UNABLE TO PUT PICTURE
I installed on an iMac runnning Windows XP Pro SP2.
I have it running with Dvbviewer Pro and it works really well, much better than the Dvbworld software. :)
Does 2104 need BDA Driver in order to scan the channels?
This is my DVB World list of Brazilian DVB channels on StarOne C2 (replaced BrasilSat4 with KU band add and more strong signals).
The HD Mux at 3700 are DVB-S2 channels, HD and SD- H.264AVC and AACplus v.2 audio
The LD(Mobile 1Seg ISDB-T) channels where deleted from the list because they are just 320x180 pixels.
Band 1Seg and
Rede TV! M
Everything is beamed to South America on that bird, I can't get anything....I'm out of the footprint. That is a nice clean picture. I am using the bda driver with dvbviewer
Anyone know - work this 2104 USB device normally with DVBDream or ProgDVB?
I can't scan channles on DVB-S2 transponders usind BDA driver with DVBDream.
In DVBWorld these chanells scanned ok, but i needed work with plug-ins available for DVBDream or ProgDVB.
Using the July 2008 WDM drivers I can get almost everything to work with DVBDream, except S2. I didn't spend much time with the BDA drivers, but I recall having trouble with Diseqc support that I need. I did a quick test of their new drivers released a couple of days ago; DVBDream seemed unable to issue Diseqc commands. The DVBWorld app worked fine, but it doesn't integrate with my other software.
Where to buy DVBWorld DVB-S2 HD 2104
Hi, I have been searching for a place to buy the DVBWorld DVB-S2 HD 2104 USB tuner, but have drawn a blank.
Has anyone here bought one direct from worlddvb dot com dot cn? I'd like to trust the western union transfer they are suggesting but don't understand why the don't accept VISA, MasterCard or Paypal.
Anyone with any experience of the money transfer purchase?
Cheers
Martin
Cheers
Martin
I did this about a year ago before Sadoun stocked the DVB World units. The transaction scheme you describe is what I experienced. It was a bit bizarre, but everything arrived quickly as promised. A friend in the UK later did the same thing with similar success.
I currently own the CA version of this product and use it with DVB Dream. I would like to add a second one to my setup. Does anyone have two of them on the same PC? I presume this is pretty common. However, one person told me that if I hook up two DVBWorld USB devices on the same machine, both will independently tune to different channels.. BUT only one will actually provide a stream; and the other one will do nothing. I would presume it goes without saying that there are people who want to use two or more of these tuners on the same setup. I asked Support@worlddvb.com for more information on this, but there seems to be a language barrier; as they mainly speak Chinese.
woooohooooo, it works, everything!
dvbdream 1.4i - latest 2104 driver
diseqc 1.2 dish positioning(powertech-v3000)
c\ku switching(BSC621-2 C/Ku LNBF)
dvb-s2, h264, scans-tunes-plays(core avc and blaze codecs)
me am 1 happy camper.
05.04.2009
DVBWorld BDA Device for DVBDream
Changes in new DVBWorld BDA device Interface:
-DVBWorld DVB-S2 bug fixed
-DVBWorld remote controls are now supported
http://www.dvbdream.org/release/dvbdreamsetup_v14i.exe
06/05/2009
DVBDream v1.4i
What is new
v1.4i (03.02.2008)
-Diseqc switch support for Creatix/CTS added
-TeVii S630 & S660 support added
* Faster scan for NA satellites
* Some TS record problems fixed
* Improved Vista compatibility, Vista AERO window movement bug fixed
* Ch. name text filtering option for general and favorites tabs
* Fix for 19.2e DVB-S2 crash problem and network search (DVB-S2 TPs)
* Now it is possible to override/correct the missing channel name or wrong crypted channel status with help of a text file. (scan_override.txt)
* BDA interface update (v2.0)
* BDA: Added support for Turbosight TBS 8920 DVB-S2, 8910 DVB-S and Compro VideoMate 500 DVB-S
* Video and audio type indicators added, next to video/audio buffer bars
* Now OSD Now/Next info should be always up-to-date
* New HotKey to change (cycle) audio pid: 'A'
* Guids.ini updated, some new h.264 entries added
* EPG parser now supports DISH and BEV 9 day epg
* Portuguese(br) language added
* * For FTA sats, you should disable "NA fast scan"
* * During fast scan, first TP will relatively take longer.
* * It is important that NA users should enable "Customize for NA"
* * You can utilize ENTER, ESC keys in channel name filter box
* * Thanks for the v1.4i tests to Chuck35, LikWidChz, inhell, t3chw00di, Dreamer, oscarr and other people in th DD IRC channel
DVBDream 1.5 beta 7
http://www.speedyshare.com/data/934211518/17905345/76563794/DVBDream 1.5 beta 7.rar
Interesting. I wonder what the DVB-S2 bug is. Any way to find out?
Thanks for the post!
05.04.2009
06/05/2009
DVBDream v1.4i
What is new
v1.4i (03.02.2008)
DVBDream 1.5 beta 7
I added a new satellite 125 West..some questions...
Problem with 95W
