DVD Camcorder Help | SatelliteGuys.US
DVD Camcorder Help
Neutron
Founding Supporter
18,716
1,124
Texas
I need to record my presentation for school. I'm using a Hitachi DVDCAM camcorder.
My presentation will be no longer than 7 minutes as required for my class. I will then need to transfer it to my PC and compress it somehow to get it to be under 50MB so that I can upload it to the school.
I bought a mini DVD-RW for this since this is the format the camcorder uses.
Once I make the video recording, will I need to finalize the disc before my PC will be able to read it? How do I go about converting the file to an MPEG-4 file, since I believe that's the best one to compress it to?
Maybe quicktime pro? It is fairly inexpensive. There are some freeware MPEG-4 encoders lying around, just a matter of what decoders you have available? QT is fairly wide spread.
Do I need to finalize the DVD-RW before my PC will recognize the video?
Will Windows Media Encoder be able to transfer the DVD file type to an MPEG-4 type?
I don't think you can finalize a RW disc. I could be wrong though, but I have never had to when I have recorded on one.
Quick Question - if it's for a school do you have access to their labs, and if so, do they have Adobe Premiere or something on par with that???!? Make it a learning experience! :)
My school is all online.
I ended up using our digital camera which records movies as Quicktime MOV files.
My 8 minute 30 second presentation ended up being 132MB.
Thanks for the help!!
