DVI Question? | SatelliteGuys.US
DVI Question?
Not open for further replies.
Poke
13,886
238
OK
Ok Im thinking about ordering some DVI Cables. First Im going to get the DVI-D and my TV has that input.Also it says that its HDCP something compliant but I dont think the DVI input on the 811 is. Does that matter and from waht I read so far the DVI-D is the way to go? :)
your Dish 811 is HDCP compliant. This is measure taken to stop people from copying or recording HDTV. you need to make sure your DVI input on your HDTV is HDCP compiant or you will not get any signal, in other words you waisted alot of money on your TV if it isn't HDCP.
Yeah it is HDCP! I just called Pacific Custom Cable and they explained all that to me. I thought that’s what is did jut could not remember. But I’m going to order me some DVI-D cable from them for like 24 bucks to see if that really makes any difference. Thanks for the info!
Check with some local computer shops. There's one across the river from me that sells the DVI-D cable, 6ft, for $12.
