First off, are you on EA or WA? It will not work with EA, nor will they even attempt to activate it for an EA account. Please advice which satellites are/will be rec'd. Or at least your location so we may determine it.
Plus, you want to plug it in and see if you hear any tick tick tick noises coming from it, indicating the HDD is toast.
By the way, they won't install a new or refurb 510. You'd likely get one of the new ViP series. Do you have an HDTV?
