I know that I need to have my phone line connected to my DVR, but what if I don't have a phone line, but I do have internet. Can I just hook my internet to the ethernet port on the DVR and then avoid having to pay the extra $5/month?
No, you have to have a broadband router with home networking for it to work. Then you can just hook up the ethernet port to your home network.
for real??? why is thatYes you are being charged for both the 625 and the 322 Receiver, 10 dollars. If you don't have a phone jack within a couple feet you can buy a wireless phone jack for about 30 bucks at radio shack, it will work as well.
Darrin
Ocala DRS
Yes you are being charged for real. The reason is that you have 2 tuners in each and they are not getting money for the second. They will waive it if you hook it to the phone line. As for the broadband, you mentioned a 625 and a 322. Not sure about the 322, but on the 625, there is no ethernet port and so it can't be hooked up to the internet to avoid the fee.for real??? why is that
Then it cost you $5 per month for Each Dual tuner receiver.but what if we dont have a home phone???
why?? why do we have to pay if the reciever is not hooked to a phone???Then it cost you $5 per month for Each Dual tuner receiver.
A reason that I have heard (that makes sense to me) is that if you were to get a Set Top Box for each TV with 4 TVs hooked up, you would be charged $15 for "Extra Outlets." By getting Dual Tuner Boxes, they waive $10 of that by hooking it to a phone line (or the internet on some of the newer models). Thus, they are giving a price break for having it hooked up.It's mainly a "because we can" fee.
The most reasonable explanation I've read is that your receiver sends out technical information that can be used to preemptively diagnose and fix problems. In theory, it makes up for the increased possibility you will have a service call. However, that answer is likely BS.
Limited time offer
