DVR 625 and a question | SatelliteGuys.US
brakmar
16
south Florida
Hi,
I have a DVR 625 (duo SD). Which model would be a good replacement? I do not mind having something similar as long as it provides a HDMI connection.
I have another question: in my location (West Palm Beach area) everytime there is 3 drops of rain (OK, let's say 4 drops) the satellite connection is lost.
Is it a normal occurrence? Remedy? I think I read somewhere that Direct TV claims a 99% successful connection no matter the weather.
Andre
Hi,
Andre
722.
your dish needs tweaking. Unless the cloud cover is masively thick, then you shouldn't lose your signal. Only time mine goes out is if it is covered with snow or if the storm coming thru is so heavy that the signal can't get thru the clouds.
Direct can say what they want, but if the clouds are thick then the signal can't get thru. If both a Dish and a direct dish are sitting next to each other and both are tweaked correctly, there shouldn't be a difference between either signal.
DISH for Westerb Arc 110/119/129 has a lower look angle to the satellites than Directv. That mrans you are looking through more of the Earths atmosphere to get the satellite signal, so even if the storm isn't right overhead you may have a weakened signal. If your satellite dish is only slightly missaligned further weakenung will cause satellite loss. In Florida you can almost count on a midafternoon thunder storm passing through so you will have more rainfade than someone in arrid Arizona.
A 622 or 722 would be the closest DVR with HDMI to replace the 625. With a HD DVR expect even more possible rain fade problems if you are on Western Arc due to 129 being very low on the horizon.
722K with OTA module will allow recording of 4 shows at once, 2 OTA AND two sat....
You will need some sort of OTA antenna but should be able to get locals even in bad weather
625 receiver with dish 500
Please help me
