P penguin48 Member Original poster May 31, 2006 11 0 Jun 27, 2006 #1 Does the HD ever turn off on this unit it seems to always be on even when unit is turned off. My 510 did not make near the noise the 625 does.
J jballa91 Well-Known SatelliteGuys Member Sep 12, 2005 29 0 Jun 27, 2006 #2 The only way it will stop making the noise is if you unplug it so it will be completely turned off. The noise of the Hd is completely normal so you don't have to worry about it. After a while you should get used to it.
B bnewt SatelliteGuys Pro Oct 6, 2003 1,485 548 Shepherdsville, Ky Jun 28, 2006 #3 I had a couple of 625's before I got one that was quiet. The 508 I upgraded from was very quiet & I wanted the 625 to be just as quiet.
RandallA Supporting Founder Supporting Founder Dec 13, 2004 10,556 68 San Francisco Bay Area Jun 28, 2006 #4 I have a 625 and I don't hear the hard drive at all. I guess you just need to be lucky and get a quiet one.
