Is it OK to remove the DVR case cover? I was thinking of removing it and either blow or vacuum the dust out. Does this void the warranty or is not allowed? Can Dish tell if the cover has been removed?
Define "alteration". No one, except Dish, would consider removing the cover to blow dust out to be an "alteration" to the receiver.Alteration...
That's crazy. I've blown so many fans and never had a problem. (That's what she said, lol)Do not blow air into the fan unless you are holding the fins from moving. It can destroy the fan if you do not hold it.
It actually can. Its more likely to damage an older fan ....That's crazy. I've blown so many fans and never had a problem. (That's what she said, lol)
Limited time offer
