I'm sorry, but only a qualified VOOM Installer has the prerequisite knowledge & skills required to professionally install and maintain your equipment.shaun-ohio said:will they also charge us 199.00 to install it or can we self install it ourselves?
dziko said:I spoke to a CSR and she told me that they pushed it back until Dec or Jan. this sucks I was hoping that it would be out soon.
Very True...but this is the problem with a JAN release date....all of us grandfathered in prices go up. Without a DVR , without any new HD CH's, without any PPV , how will they intice people to stick around? I really think they have to roll out the DVR before they increase prices. They dont need to give their most valued and truted subs a reason to jump ship.JimP said:If you've ever worked in a computer programming environment, you know that its next to impossible to give definate dates as to when problems can be found and fixed.
December or January basically sounds like they don't really know. They will get it, just not as soon as we'd like to have it. That being said, I'd rather wait and get one that works mostly right than to swap out boxes a couple of times and go through endless months of problematic software.
At minimum, changes have to be made to the EPG and Middleware to support upcoming PPV and DVR features.joemama said:Why do you assume that any software to support DVR will be included in releases for the current hardware?
I asked that questions a few weeks and received very little feedback. The consensus is Yes, these boxes could be turned into a DVR, but I doubt that will happen since the hardware may be outdated and, more likely, the install techs (same lame Installs Inc. installers) won't be capable of performing the upgrade.Are the current boxes field upgradable for a HDD?
I work in tech support, so I field the technical problems, and deal with both developers and testers on a daily basis myself. With new software releases, not only do you have to test every little tiny aspect of the new features that are being added, you have to make sure that nothing that is currently functioning properly gets broken. It is very common for existing features to get 'broken' with a new release, even though they weren't supposed to change. Depending on the software release, this regression testing can be just as thorough. as the testing of the new features.kemguy said:>>>If you've ever worked in a computer programming environment, you know that its next to impossible to give definate dates as to when problems can be found and fixed.
As a computer programmer who works in a TEAM of programmers, I can ditto that statement. The product we are working on today was supposed to be released 6 weeks ago. When you have a program that consists of hundreds of thousands of lines of code and a host of beta testers, it is damn near impossible to find every single little issue. You only hope to find the ones that interfere with the masses.
Eric_C said:has anyone taken one of the current boxes apart?
Limited time offer
