I do believe that the entire stream of information is saved on the hard drive when you record shows, so there is not any loss, therefore no difference.
I don't see any difference either. Why would you want to change the recording quality?
What the TiVo was doing was compressing the data to make it smaller. I don't know what the settings were, but "Best Quality" basically means the data as it's rec'd. I'm sure they then used a term like "Least space" which in turn means horrible quality !In TIVO recorders, you can set the recording quality. why is this feature not available to dish receivers?
It is just a thought. If this feature is available, I would record my favorite shows in highest quality setting and the others in standard quality.
The TIVO was actually compressing data while recording, since it had analog inputs only. This compression could be done with different quality settings (better quality = more space needed).In TIVO recorders, you can set the recording quality. why is this feature not available to dish receivers?
Yes, the conversion alone degrades quality. Just anyone who watches analog channels through a digital set-top.Even the "best quality" on Tivos is not the same as the original broadcast as it has to encode it from analog to digital.
The digital bit stream from the satellite (or an OTA channel) is recorded without any changes. The playback quality is the same as watching the program live.
I am wondering whether there are any quality differences between playing recorded shows from the DVR and watching live TV.
That's not quite what caam1 said! Just to clarify a little more, the DVR does not record the "complete digital stream from the satellite", nor even the complete stream from a single transponder. Rather, it records the transport stream from a single channel (demultiplexed and usually decrypted from the complete stream from a single transponder), and adds a few more bytes from the previously-stored program guide in ancillary files associated with that program. I imagine that's what Cold Irons meant to say.Like caam1 says - the DVR records the actual, complete digital stream from the satellite.
When you watch playback, you are watching at exactly the same quality as live - you're watching the same digital stream of information.
Limited time offer
