You can turn that option OFF in the System Settings, under Power Saving ...
skew said:I hooked up my killawatt the h25 was 11 watts on and 9 watts standby not worth the hassle to hit ok everytime I used it. So I just diabled it. But I would use it if they would disable the nag screen.
I think it's safe to assume an HR24 or HR20 doesn't benefit much from the use of the power saver. Thanks for checking.
2 hours is too short!
It keeps poping up while I am watching TV and then I got to scramble and find the remote before it turns off. It should be maybe 4 hours not 2.
Limited time offer
