DVR625 tv2 snowy picture tv1 ok HELP | SatelliteGuys.US
ederd60
3
dvr625 tv2 picture is snowy, had another tv a while back same place had great picture. TV1 has great picture,talked to dishnet no help. hooked tv2 up with short piece of cable no change ,just to rule out bad connection. Any help is apreciated! ederd60@bellsouth.net
Best bet is to go into the menu, under installation then modulator setup. You'll be able to see what channel tv2 is on, most likely 60 or 73.
If your on 60, make sure your tv is in Antenna mode, not cable.
Costco Selling 622 with Rebate, what is the rebate
finding satellite 129
