DVRHD34 channels numbers not showing ? | SatelliteGuys.US
sportman13
352
4
When I change the channels on my DVRHD34 Genie it is not showing the channel numbers or clock what is the fix to this please
How long do you have the banner time set for? 2 seconds? 4 seconds?
Sportman you're talking about the banner that shows up on top with the time and channel number after you change channels, correct?
So, how long do you have the banner set to display after a channel change? I believe the options are 2,4 and maybe 6 seconds.
It bet it is the new xx740 software. It's happening to me. As well as the problems described in the "Pixelation/Freeze Up..." thread.
Where's my HR24 when I need it...
good to know. sorry sportman......
ejb1980I you said you got this version Wednesday. Since then, my HR34 Genie has been worthless. My HR34 Genie freezes to what are you going to do about your HR34 Genie and its freezing ?
FXX and FS2
Fox Sports 1 Issues
