eagle aspen c band | SatelliteGuys.US
eagle aspen c band
macssam
4
us
i have a dm800hd and i am having trouble setting up my eagle aspen c-band lnb with it. the lnb is hooked up directly to the receiver. my settings are lof/l 5150 lof/h 5750 and threshold 00000. i am only able to receive vertical transponder. i can switch the lof/l with the lof/h and i get the horizontal but no vertical. am i missing something?
ok i figured it out. you have to edit the satellite.xml witch is located in /etc/tuxbox and lower every horizontal transponders by 600Mhz.
INSP (G1-17) leaves analog
Ended activations of 4dtv? What do they mean??
