East and west on 44 switch | SatelliteGuys.US
jawxx
114
2
United States
Ran into an interesting situation today. Apartment building. Currently has 1000.2 WA fed into a 44. There is also a second 44. 129 is failing due to l.o.s. Landlord will not allow dish relocation. There is both HD and SD accounts running on this setup. The balcony on which the current dish is located has l.o.s. For 1000.2 e.a. The landlord may allow a second dish on the same balcony.
Question is: While i know a 61.5 wing could be fed into the 44 no problems and either a k.2 east or west can be fed into 44 no problems, can i feed 110/119 into ports 1 and 2, and 61.5/72.7 from a k.2 e.a. Into ports 3 and 4? My only concern is the sd setups seeing the e.a. and getting confused as e.a. Dishes are not compatible with sd equipment but the first 2 sats would satisfy SD needs and the second 2 HD needs
No problem. Switch passes any of any 4 sat inputs to any of the 4 outputs. So you can mix any 4 of 129, 119, 118, 110, 77, 72 and 61.5.
I
Sent from Galaxy S4 using SatelliteGuys
Thanks for replies, locals for Madison, WI are 61.5 & as long as i dont alter ports 1and 2 (119 / 110) i shouldnt knock out anyone else since the sd receivers will not look for channels on the heretofore absent 129. I beieve therese only 1 cust on HD and that's the one being servicded later this week
MLB Network no Alternate
What should I do to get the $40 DVR enable?
