East Coast...install question | SatelliteGuys.US
williamkmurphy
142
Bills Country
I justed moved and Dish installed new equipment on the roof, I am not sure what exactly the second coax line is for.
Old Setup:
Elliptical Dish(3 sats) + 61.5, 4 lines down to dp44 one coax to 622
New setup
Dish for 110 and 119 and dish for 61.5, one pair of coax lines come off of the roof. One of the coax lines goes to my 622, the other is just hanging out in the basement.
Can I run another dual tuner box off of the second coax line if I wanted to? Do I need to anything special if wanted to run a single tuner box...the vip211 purchase price is pretty reasonable.
Assuming we're talking about DPP44 (not DP44, which I don't think exists) - You can run 4 singles off the DPP44 or you can run 4 dual tuners with DPP Separators on the receiver side of the connection. You can also run any combination.
If you don't see any external switch, then the installer probably used a DPP Twin, which has the input for the 61.5 built in.
In that case, yes... you could add an additional receiver with no problem.
Good experience w/ tech support
Audio problem on 622 with Dallas NBC affiliate
