East Coast Satellite Image | SatelliteGuys.US
spongella
1,625
1,236
Central NJ
NOAA 15 made a pass overhead around 6:45 am, got this view of East coast from the bird. Nice and clear, clouds are offshore.
Hi fred555, just using an old Radio Shack discone antenna mounted on the chimney.
Excellent because that's exactly what I have. I need to mount it on my workshop soon.
Are you using a dongle or something more exotic?
Nothing exotic at all, just a $13 dongle. Using narrowband FM on SDR# and WXtoIMG software with Virtual Cable software to feed audio from SDR# to WXtoIMG.
I'm good to go because that is my exact setup. I just need to mount the antenna, outside, on my workshop.
Reactions: spongella
To make it more interesting you can track the satellite on N2YO or Satview and see at what elevation you see the signal and hear the audio tones.
I found there are times that I can hear the audio tones before the signal shows up on the water fall.
I also have the Orbitron plugin for SDRsharp so I can have Obitron take care of the Doppler tuning.
Happy Satellite hunting.
Spent time today checking out the best Antenna for NOAA satellites. I have a 2 Meter J-pole on the roof, an in the attic Diamond Discone and an home brew Quadfilar antenna, that I set up in the back yard as needed. So far The Quadfilar works the best.
