EASTERN ARC 61.5-72 | SatelliteGuys.US
EASTERN ARC 61.5-72
BRIAN BOWERS
6
3
AUBURNDALE, FLORIDA
OK FIRST TIME WITH THIS LNB.... I HAVE NEVER HAD ISSUES WITH 110-119-129 SET UP...PLUG IN GET ELE, SKEW AND ASMTH AND GO. I CAN NOT GET THESE READINGS FOR 61.5/72 WHEN I PLUG INTO RECEIVER (VIP211K) . I GOOGLED EVERTHING I CAN THINK OF...NEG RESULTS..NOW I SIGHNED UP HERE HOPING FOR AND ANSWER. I LIVE IN AUBURNDALE,FL 33823. THE ONLY THING I CAN THINK OF IS IT IS FIXED ON 61.5-72. I CALLED A FRIEND WHO LIVES IN ST. PETE,FL 33708. I ASKED HIM WHAT HIS ELE/SKEW/ASMTH WAS...55-90-237... CAN ANY1 HELP. THANKS.
Did you run a check switch?
Disconnect cable from rear of receiver, run check switch to clear satellites from receiver memory.
Re-run check switch with cable connected to get correct satellites in receiver.
Reactions: charlesrshell
Skew is 69, Elevation is 55, Azimuth is 159 for Auburndale so your settings are WAY off
Reactions: NYDutch
A switch check has to be performed in order for the box to see signal
Sent from my iPhone using SatelliteGuys mobile app
Issue Transferring to EHD
Oh where, Oh whereis Dishanywhere?
