Eastern NC: My antenna install | SatelliteGuys.US
brice52
54
43
Wallace NC
I just got my 30 ft tower up and running with ant751r antenna pointed at magnetic 64 degrees
I have 200 ft of rg6 with antennas direct DP 019 preamp
I n the utility room I have the power inserter and a signal distribution amplifier
these are the midmorning signal
these are from The Dish Hopper OTA sectiom
Wilmington
WWAY Strong 100 WECT Strong 100 WSFX Strong 100 WUNJ Strong 100 ....... these are at all times
Greenville
WITN ok to weak 68 to 82 WCTI OK to Strong 85 to 100 WPXU Ok to Strong 88 to 100 WNCT OK to Strong 82 to 100
Weather affeccts the Greenville reception
It was last year received WITN at 100 as with WCTI WPXU was 82 to 94 WNCT 100
Out of Wilmington WWAY 100 WECT 100 WSFX 82 to 94
Overall with the exception of WITN I have more stable reception with the system I now have
Reactions: k.r. and FTA4PA
update on reception
Wilmington the same
Greenville
WNCT in poor range on Rabbitear report is locked in Strong
WCTI in Fair range is locked in Strong
WPXU in fair range is locked in Strong
WITN in fair range, weak to OK
WYDO in fair range, weak to no signal
WNUM is good range but I can not pull it in
update on reception
Wilmington the same
Greenville
got new preamp system installed yesterday surely makes a difference
WYDO and WITN are now full signal
Reactions: FTA4PA
Now all stations are locked. This morning I checked my signal on each station and found with the rain the signals were bouncing up and down. Watching TV they still have a good signal.
