EchoStar 25 @110W as early as 1st Quarter 2026. | SatelliteGuys.US
nelson61
8,861
9,005
Where it's Warm
EchoStar has filed with FCC for license and launch of the EchoStar 25 satellite at the nominal 110W slot.
------"At the nominal 110° W.L. orbital location, EchoStar is licensed to operate over 29 of the available 32 DBS channels (specifically channels 1-27, 29,and 31).3 Currently, EchoStar provides service over these channels from the 110° W.L. cluster utilizing the EchoStar 10, EchoStar 11 (in inclined orbit), and EchoStar 23 satellites; and from the 119° W.L. cluster utilizing the EchoStar 14 and EchoStar 15 satellites. EchoStar anticipates that EchoStar 25 will be ready for launch as early as the first quarter of 2026. EchoStar anticipates that EchoStar 25, a spot-beam satellite, will take over delivery of certain programming services from EchoStar 10 and 14. After launch and in-orbit testing ("IOT"),4EchoStar 25 will proceed directly to 110.0° ± 0.05° W.L. Once EchoStar 25 is placed into operation, EchoStar 10 will initially remain at 110.2° W.L. serving as an in-orbit spare and may ultimately be relocated subject to all appropriate Commission authorizations. EchoStar 14 will remain at the nominal 119° W.L. orbital location and serve as an in-orbit spare once EchoStar 25 begins service." -----
-----"The ECHOSTAR-25 satellite includes thirty-six 150 W saturated transmit power capability
TWTAs, nineteen 165 W saturated transmit power capability TWTAs, and two (2) 35 W
TWTAs for telemetry in contingency mode. At the nominal 110.00° W.L. orbital location, ECHOSTAR-25 will use up to fifty-one active transponders producing peak EIRP levels as high as 61 dBW for CONUS spot beams and 60.9 dBW for a Puerto Rico spot beam. "-----
Transmitting????
Content is king.
yes
FCC made some major upgrades to their records system this summer and I had to do some digging to find the right files..
A preliminary look at the contours using the ITU system indicates it is a conventional spot beam satellite similar to their other newer satellites.
It will take me some time to generate all the Google Earth spot beam contours. Will post a link when I finish.
What's the difference in the Joeys?
EchoStar Announces Spectrum Sale and Commercial Agreement with SpaceX
