Echostar 7 119W Spotbeam Maps | SatelliteGuys.US
The North American beam map of the 15 E7 spotbeams.
Nice map. If you compare the E-7 spotbeams to those of E-10, E-12 or Ciel-2, one can see how far the capabilities have progressed in the last 8 - 10 years.
Not really.
E* skimped on the spot beam on E7 and E8 because of Charlie's shortsightedness.
DirecTV spotbeam birds built and launched around the same time as E7 and E8 have more beams than E7 and E8.
Not really.
E7 was designed with only 2 uplink centers in mind is why.
Question: Is there a rough dish size for the green circle and for the yellow circle ?
Amazingly, some DMAs are partially outside the green circle.
PS If they can be re-done with a little more space around the yellow circle, and without the copyright text, NOAA text, etc. etc. that would be helpful (although I could understand that the latter may not be possible).
These maps are designed with a typical DishNetwork installation in mind. Yellow circle works just fine.
If I zoom out any farther it loses the details of interstates and such which helps people figure out where they are at on the map.
But the 3 or 4 rows of type along the bottom do the same thing.
Perhaps an extra set could be made that zoom out enough to put the type outside of the yellow circle ?
Signal Distribution Question
Laredo TX HD/SD Local Channels
