EchoStar 9/Galaxy 23 at 121.0°W --Can't get 2 TPS | SatelliteGuys.US
absentfriend
15
victoria, bc
3900 V tp 10 and 3780 V tp 4
Are they gone? I can get most of others list in lyngst, but not them...tried 3 hours, blind scan many times :(
Can someone with Cban take a quick look?
Yes, both are there.
Thanks...I fould the problem, it's the captive works 800 I used...:(
I switched to pansat, it comes up...
:mad:...3 hr waste...
Updated:
give up for today...
3900 V is so weak, can't lock it with 6ft fortec prime focus dish...others fine...
So I has fortec 1.8 Meter prime focus dish, and BSC621-2 lnb...
I was able to lock most of the TP on 121W except for 3900V, I tried my best to lock it, but the quality at most stopped at 20...
So my question is what else I can do to lock it?
I also use fortec 1.8m prime focus dish and BSC621-2 LNB, and I'm in greater Seattle area.
I locked 3900 V (ETTVs and AJE) fine, quality 65-67% on CS 4K, and video/audio are fine.
I have problem with 3780V, I lock this tp fine, Q:65-67%, but videos and audios are garbled.
ANOTHER C DISH ON CRAIGS MPLS/ STP
10' Unimesh value?
