Picked up a couple of ECODA 22KHz switches. Did a temporary hookup with the SV 8000 to test the switches. SV connected to the 22KHz off side and PBS came in w/o any problem. Signal 64, Q 43. Turned 22 on and signal went to zero. OK switch works that way.
Shut down, changed connection to the 22 "on" side, powered up and, what, I had PBS? But 22 was "off". Was getting signal 30 and Q 6. Turned 22 "on" and signal went back to 64 & Q 43. This appears the switch "leaks" on the 22KHz "on" connection. Is this the way these switches work or do I have some low quality knock offs?
RT.
![DSC02220[1].jpg DSC02220[1].jpg](https://cdn.satelliteguys.us/xen/data/attachments/54/54035-2191859b4ecf90c6f5d40ee01c694cb9.jpg?hash=IZGFm07PkM)
RT.
