Edision OS Mio+ Picture-in-Picture | SatelliteGuys.US
  • Thread starter Thread starter cyberham
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
cyberham
5,477
4,266
Halfmoon Bay, BC
I have tried using Picture-in-Picture on the Mio+ before, but it was never so useful since it only allowed a PIP window in the upper right corner of fixed size. I've stumbled on a new PIP configuration method if I use the Media Player. It is in the Menu of Media Player and is labeled "0 Menu PIP". There is a "Move Picture in Picture" command which allows resizing of the PIP window as well as moving the PIP window. I find the best position to move it is beside the main window. So on a multi-cam feed, you can position the PIP window beside the main window. I haven't found any way outside of using Media Player to do this. This allows me, for example, to simultaneously monitor both Newsedge feeds on 99W Ku or both CNN feeds on 87W Ku.
Once set up using Media Player, the configuration remains even if using the satellite mode.
