EHD Code 852 | SatelliteGuys.US
EHD Code 852
charlesrshell
SatelliteGuys Crazy
11,247
5,977
O'Fallon, IL
I get error code 852 just about every morning on both HWSs on CUI software version U234. A WD EHD is attached to each Hopper and they both work good. Anyone else getting this and what can I do to stop it? Thanks
I don't have a Hopper and I have not seen anything posted about it that I remember. If it doesn't affect any recordings etc than I guess just clear it each day. The best thing I can think of is to unplug the EHD, restart the Hopper. After the Hopper is up and running plug it back in.
Reactions: charlesrshell
OK, thanks. I will try that out when I have chance.
No luck Tampa8. Did the procedure on one of my HWSs and this morning when I turned on the Hopper, got the same popup window 852. No big deal, just wonder what's causing it.
Reactions: Tampa8
My Hopper 3 has an EHD and I never see this message. [KIDDING]My guess is it's a subtle kick-in-the-tenders to get you to switch to the Hopper 3.[/KIDDING]
I don't know if the message shows up on my Hoppers when they're powered on because I have manual timers set for them to turn on every morning at 5:30 and tune to the news so they're on and buffered up for skipping commercials whenever I turn on the TV. :)
I have to click the OK button in the 852 popup to get to live TV. So I would think you are not getting the message 852 in your Hopper. My other HWS hasn't gotten the message for about a week now. Just this one Hopper has the issue. I performed the procedure in post #4, but no help.
Reactions: JSheridan
How long have you waited without clicking the OK button? Does the message time-out eventually?
Okay. I was just thinking that if you followed JSheridan's advice and set a timer to turn the Hopper on early, then maybe the message would time out by the time you turn the TV on.
I checked this morning and yes, the message does time out after about five minutes, then the HWS fires up.
Reactions: pattykay
Problem with pausing and resuming
Moving to a new location for real
