EHD content, post-construction | SatelliteGuys.US
lacruz
83
My condo association is doing major work to our building in Spring of 2013. I have two dishes on the balcony and will have to take them down during the work, which is slated to take seven weeks. I plan on keeping my Dish account active during this time for a $5 fee per month, I think. My concern is that I have several EHDs full of recordings from both my 622 & my 612. After I reactivate my receivers, post-construction, will the receivers still recognize the EHDs, or will they try to reformat them, erasing all content? I read on here before that DVR content stops working after a couple of weeks if your receivers are not getting a signal from Dish. What about EHD content after seven weeks, after the account is placed on the $5 plan? Thanks in advance for all advice on this.
As long as the account remains the same the EHDs should work. Since you are not cancelling the account you have nothing to worry about.
The ehd's are turned on and kept live as a programming "Tier". So, with your dishes down for 7 weeks and your receivers not able to get Hits, they will most likely stop working after a period of time. However, after the account is re-activated and the receiver back in the stream, they should come back just fine.
Lost OTA guide info after re-scan
signal meter for Eastern Arc
