EHD installation help needed | SatelliteGuys.US
dfer777
16
arizona
So I hooked up a WD 1TB to the front USB port.
went to My Media Transfer in my menu,should I see EHD in Transfer to: box?
when I go to Home Media Device list and hit Refresh it scan's but nothing comes up.
:confused:
What receiver are you using?
Did you get any prompts about the HDD needing to be formatted?
Thank you, sethwell.
Turns out EHD was not spinning.
Off to Best Buy... 1TB Western Digital My Book AV.
Is that the preferred EHD?
El Rey network coming to Dish?
SUGGESTION for the GREEN button on the Remote control
