Eliminate TV 2 | SatelliteGuys.US
Eliminate TV 2
I have eliminated TV 1 how can I hook up TV 2 to the HD signal on a 722k
You can't .
TV1 is the only output that has HD options.
TV2 is coax 480i output only.
If you want HD DVR to 2 rooms, get two 612
OR a Hopper and a Joey.
Samsung Galaxy S6 Active
Yes of course! Just plug your newly-repositioned TV1 into either of the HD outputs of TV1 on your 722. These include hdmi and component outputs. All the rest, including all the outputs for TV2, are SD only.
Reactions: KAB
I want to move the TV to the room where I had TV 1 but it says no signal can I make it work
So...you have moved the TV that was in the TV2 location such that it is now where the 722K is physically located, correct? How do you have the 722k connected to the TV?
Have you changed the TV to the proper "Input" to match the connection with the 722k, or are you still looking for the signal on the "channel" that you used to use when it was connected as TV2 in the other room?
I think the OP has actually moved the receiver itself to where TV2 was & has now screwed up how the signal gets from the dish to the receiver...
That was my first thought after reading the first post, but then their last post made it sound like maybe they'd moved the TV to where the receiver was already located. For sure, I think we need a little more clarification to help them.
Unable to create a daily manual recording schedule on Hopper3
For Dish, Slinging OTT Might Pay Off
