Nope. It has a receiving angle of 3 degrees. Rainbow 1 is at 61.5 and the new one is at 72 degrees. So, they are too far apart, and require an elliptical dish that has multiple focus points to catch both birds.jabroni said:Will a 24 inch dish be capable of receiving the new sat? I am thinking yes......
I doubt it would do you any good until Voom programs a/the channels into the STB.... unless you can manually tune in the channels from the option menu... that would be a bummer, if you had to do that every time you change channels...pmalve said:Could I use my original Voom dish for the 2nd satellite? I changed my dish to a 30" dish soon after getting Voom and have the old dish sitting in the garage. What kind of switch would I have to get to combine them?
Impatient said:Nope. It has a receiving angle of 3 degrees. Rainbow 1 is at 61.5 and the new one is at 72 degrees. So, they are too far apart, and require an elliptical dish that has multiple focus points to catch both birds.
voomvoom said:I doubt it would do you any good until Voom programs a/the channels into the STB.... unless you can manually tune in the channels from the option menu... that would be a bummer, if you had to do that every time you change channels...
Limited time offer
