Empire network closing doors what will be the replacement? | SatelliteGuys.US
None. Dish might extend the MSG and FSNNY contracts out to western new york, but that would be spending more money heh ;)
I will be paying for the top 160 and I will not get 160 channels I will calls them up. If thet don't add a replacement or give a discount I will switch to cable.
Whaat???
which one you gots? AT120 or AT180? Loosing 1 channel does not void their package.
Remeber that RSNs are only servered to certain areas and their is no requirement for your area to have an RSN, so technically they don't have to put in another RSN...
I mean top 120. Time warner cable here in syracuse,ny has four local sports channels local time warner sports channel,YES,MSG,and FSNNY
Yes, ok. Well then put some pressure on dish to provide equal service or switch to TWC :)
What, it's already gone?
Oh wow that's lame. Talk about a pre-empted move. Of course d* will keep carrying it until it goes dark....
I guess E* loves removing channels more than adding them :(
what ever happened to nbr on 5x rec
PRESS RELEASE: Moody's Affirms Echostar Rtgs >DISH
