Equator duplicated on FSFLHD? | SatelliteGuys.US
tdillon
Loster then I Founder
317
Right now I am watching the Eye Over Italy on channel 341, which should be Fox Sports Net, Florida HD. It is the same video as channel 122 Equator HD, but the sound feed is slightly different. Only stereo instead of 5.1.
Is this a problem with my STB or do you think Voom is experimenting right now?
I thought that maybe my LNB might be botched, but the normal channels that I check for a polarity problem are all okay right now (261). The program guide for FSFLHD shows that it should be off the air right now.
Voom is experimenting right now, since there won't be any programming on FSN-FL until spring (assuming the NHL never restarts) they've been using the channel for testing.
Used Voom Receivers
knbc 4
