Equity on 95W? | SatelliteGuys.US
Equity on 95W?
LoTech
498
Whitesburg, Kentucky
Does anyone have any idea how long the Equity stations might stay on Galaxy 3C (95W)? I'm going to be getting my 1.8 m fixed dish this weekend, and wondered if it would be worth the effort to try to get the Equity channels, or if I should set it at 99W.
-LoTech
unless you want Spanish channels the only English channels on there are
WMQF (same as G18)
Daystar (same as G18)
WBIF...This TV
I personally went with 99W :)
Also those chanenls have a 7/8 FEC so you need alot of signal quality or you'll have pixeling. Even at a 75 quality on the Pansat 1500 I get pixeling once in a while
Just starting - Help/advice
.TS files What software do you use ?
