Error 122 | SatelliteGuys.US
Error 122
beetle02
81
15
Middle Tennessee
Monday I got error 122 "An internal communication failure has been detected. Press "select" on your Remote Control to reset your receiver". The screen was locked up. Pressing select on the remote did nothing. I reset the receiver from front panel and it reset OK. This morning I got the same error and had to reset the receiver to clear it. Is this a sign my H3 is dying?
Try unplugging the H3 for a minute and then plug it back in. If that doesn't fix it you just may have a dying H3...
Channel Dispute frankly channels as of 11:55 CST
Issue with tuning to FSN regional sports channel
