ERROR 311 | SatelliteGuys.US
ERROR 311
unplug box and allow to come to that screen at least 4 times, if still get it, go to system info and check field f, if its red you are bad box, also check value:7 on the details screen of system info, if its a number other than a 4 after the 7, then box has hard drive failure
My 722 has started getting this error - three times in the past 2 weeks. The only thing that brings it back is unplugging the power. Tech support says I need to have the unit replaced as it is a failure with the hard drive. Fortunately I can dump my programming to my external hard drive as the 722 still works for a while once it comes back up.
Audio skips on recorded HD locals when playing from 622 DVR
Ola Quetzsat1
