N No_Brains SatelliteGuys Pro Original poster Dec 28, 2007 226 0 Princeton, WV Mar 31, 2009 #1 i'm trying run windows updates i get error code: 8024402C what can that be
mike123abc Too many cables Supporting Founder Sep 25, 2003 25,726 5,043 Norman, OK Mar 31, 2009 #2 there should be an option to click come up that will take you to microsoft's support site. There they usually have step by step guides on how to fix the particular error. Windows Update error 8024402C - Windows Vista Help
iwc5893 SatelliteGuys Pro Feb 1, 2007 2,178 0 The desert of WA, zip code EIEIO Mar 31, 2009 #3 The best way to fix a Windows error is to switch to Mac or Linux...
R rkel Active SatelliteGuys Member Feb 1, 2009 16 0 North Carolina Apr 12, 2009 #4 Try turning off your virus protection. Mine won't let me install updates until I turn it off.
