im now able to view live and replays on ESPN 3 on the ESPN app on my Genie. Not sure when it returned.
Never has. Wouldn't expect it to come to them. Glad to see ESPN3 back on my HR44!does the espn app not work on the genie mini's?
Go to most any ESPN channel (206 207 208 209 466 611 677, doesn't work with 614 or 615 which are SD and part time anyway) and press the red button when prompted.How are you guys getting ESPN3 on the Genie (thats what I have my ROKU for) ?
When I go to the D* Apps, I Get :
The Players Experience
iHeart Radio
Scoreguide (use to use all the time till they screwed it up a few years ago.)
The Weather Channel
Entertainment Extras
Att Digital Life
and Whats Hot .....
Thats it.
Thank You, I will check it out after my show is over ...Go to most any ESPN channel (206 207 208 209 466 611 677, doesn't work with 614 or 615 which are SD and part time anyway) and press the red button when prompted.
It only works on main HRXX Genie 1 units, not any clients.
Sent from my SM-G920V using the SatelliteGuys app!
Thanks again, I did get it to work ...Go to most any ESPN channel (206 207 208 209 466 611 677, doesn't work with 614 or 615 which are SD and part time anyway) and press the red button when prompted.
App comes up for me but will not play live games. Says something went wrong.
What is LIVE this time of year, I only use espn3 during football season ....
Limited time offer
