ESPN Interactive | SatelliteGuys.US
ESPN Interactive
jshecket
11
Anybody else find the new ESPN Interactive feature incredibly annoying? Unlike the equivalent feature on CNN, it comes up on its own every time you press anything on the remote. It disables DVR functionality, which I think is the real motive at play.
I found it by chance. Look at channel 100 (Dish Home), then select "sports". It's the first entry in that sub menu. I also found it kinda hard to use until I realized you have to hit the "#" button on the remote once you are in the actual ESPN InterActive application, then hit Select again before the remote will actually function correctly inside that application. It does seem to have some good stuff, like scores of games, etc., just very hard to use with the current setup. By the way, I am describing how it works with my 311 receiver and remote, others may work differently.
Dish Remote Code for Dell Computer
Adding a new receiver.
