Has anybody had issues receiving the ESPNHD broadcast? I can receive it on my SD tv but not my HD??
VOOM service is no help.
Dvlos said:With the diplexer both units have to be plugged in an at least in Standby mode, because the voltage is split between the two.
If your TV is capable of 1080i isn't the question is it capable of 720p?
Is your coax cabling grounded?
Are you having problems with StarzHD (channels 261/262)?
What do you get on your screen when you tune to ESPN-HD?
wmichsabre said:I am assuming that my TV is capable of 720p. It is a 55" Mitsu - about 5 months old.
I will check to see if the coax is grounded.
I don't subscribe to StarzHD, so I can't check it.
When I tune to ESPNHD, I get a black screen with the message to call 1-800-GET-VOOM to upgrade.
Seanb61 said:Is your box set to output native or 1080i? perhaps your tV can't handle 720p (ESPNHD is 720p)....try setting the box to 1080i
mattyro said:Dont start worrying about your gear-- ESPNHD was a nitemare all nite for me--sd was fine. I rebooted, tuned on and off- the whole deal but ESPNHD was nothing but pixels and smear. I think its ok now--I havent checked recently. I also have espnhd thru Comcast and thier feed was fine!
wmichsabre, this problem is usually caused by improper wiring or bad LNB. Please check the Troubleshooting section of the FAQ and the following thread:wmichsabre said:I do have problems with StarzHD - BravoHD is on 261, and I can't get 262. In fact, a few of the channels have different feeds than what is supposed to be broadcast?!?
Limited time offer
