external harddrive question | SatelliteGuys.US
35LKSA
103
2
Eastern PA
i am having directv installed today. i have a bunch of movies on an external hard drive from dishnetwork.
does anyone know if they will work with my directv reciever, when instaled?
No, it will not work.
When you plug in the ehd to the D* recvr it will reformat the hard drive and set it up for the |* recvr and you will lose your movies in the process.
No, they will not, also be aware that Directv uses eSATA drives that take the place of the internal when on...
Do I understand you in that if I plug in the external drive, IT will be used for recording rather than the internal drive?
I have been using the external drive to store movies that I can watch much later. I use the internal drive for short term recordings that I delete when done.
Picture quality on NFL ST
Help Please! HR24 and No Sound on HD
