F/S Or Trade Radio Shack Pro-97 Scanner | SatelliteGuys.US
stogie5150
Crazed Cajun Rebel
3,839
85
Slidell,LA
I have a Radio Shack Pro-97 scanner I'd like to sell. It is less than three months old, I used it once, no longer need it anymore. I have all the original packaging, both battery holders, as seen in the pics below, I am including the 20.00 SERIAL ( not USB) programming cable and a 20.00 extended center loaded antenna with the deal.
$150.00 and I'll cover the USPS Priority Mail shipping to your door. Or, if you prefer, I'll entertain partial trades for FTA equipment, however I would like some cash out of the deal,say 50/50 split. Or make me an offer I cannot refuse. :)
I can do Paypal, no problem. I have 100% feedback on Ebay, by the way. I am not going to take your money and run. :up
Someone asked for more info...this is from the Pro-97 Wiki, here
Pro-97 - The RadioReference Wiki
Features
  • Discriminator output modifiable? YES see this article on the IdaScan.com site for instructions
  • 1000 channels - 10 banks
  • Frequency Coverage: 25-54, 108-136.9875, 137-174, 216.0025-221.9975, 222-225, 225.025-405.975, 406-512, 806-960 (excluding cellular) and 1240-1300MHz
  • Scan rate 60cps
  • AM/FM/CTCSS/DCS mode selector
  • 5, 6.25, 7.5, 12.5kHz steps (8.33 steps in 108-136.9875MHz air band)
  • UHF/800/900MHz Motorola/EDACS/LTR Trunking
  • Triple conversion Superheterodyne receiver virtually eliminates image-type interference
  • Signal stalker II
  • 5 ID lists, 30 IDs, 150 per bank; 1500 IDs total
  • L/O ID in "Open" mode
  • ID delay
  • Motorola Control Channel Only trunking
  • 16-Character Alpha-numeric display for ID tagging allows frequencies to be easily identified by the name you assign to them
  • Lighted keypad for use in low light
  • 3 programmable skywarn channels
  • 20dB attenuator
  • Digital weather alert/priority indicates watch, warning, statement or test statement along with seven preprogrammed NOAA WX stations
  • Five service search bands for marine, fire/police, air, CB and Ham bands
  • Search 'Seek' feature
  • Zeromatic search tuning
  • One priority channel
  • PC interface, cloning
  • Key lock for safety
  • Key tone on/off
  • Low battery indication
  • Power save
  • EEPROM memory backup
  • Rotary volume control with switch and rotary squelch control
  • Includes belt clip and 6" flexible rubber antenna
  • Two battery cases—one for (4) alkaline and the other for (4) rechargeable batteries
  • Size: (less antenna) 6-1/2x2-5/8x1-3/4"
  • Jacks: earphone, PC interface/cloning and external power
  • BNC antenna connector
  • A cloning cable may be fabricated using 2 1/8 inch mono jacks and shielded cable
RR System Compatibility
This scanner is compatible with the following Trunking System Types and System Voices used in the RadioReference Database, of course you must verify that the scanner will cover the appropriate frequency range:
  • System Types:
    • Motorola Type I
    • Motorola Type II
    • Motorola Type IIi Hybrid
    • Motorola Type II Smartnet
    • Motorola Type II Smartzone
    • Motorola Type II Smartzone Omnilink
    • EDACS Standard (Wide)
    • EDACS Standard Networked
    • LTR Standard
  • System Voices:
    • Analog
