Familyfriendlye channel gone? | SatelliteGuys.US
sbrown1357
19
Wichita Falls, Texas
Familyfriendlye channel on Galaxy 23 tp 9 moved to tp 1 per lyngsat and there web site.
i get all the other channels on tp1 but not Familyfriendlye channel. does anyone else get this channel if so what info can i use to get it
thanks scotty
I didn't have 121W Galaxy 23 programmed into my receiver so I just went up anddid that. I did a blind scan and family friendly entertainment was there at TP1
3722 V SR 1591. It doesn't seen to have a strong signal, I could only get a 70 quality with an 86 signal but it is there. What kind of signal/quality are you getting? I would do a blind scan and if nothing comes in then manually enter the TP. If it is already there then delete it and then re-enter it and then scan it.
FTA Question
I wonder if any of you would find this useful.....
