Feature Request: OTA-SSU Firmware Version Information | SatelliteGuys.US
Raycock
37
Clayton, North Carolina
One feature that I would like to see is when you go to the update screen, the system shows
Next: Downloading
Press Ok to Start Download
H/W ver: 0.1
S/W ver: 0.0.12
S/W size: 1904731
It would be nice to include whether or not the Software Download is equal to what is already installed or you will be downloading the update like it use to do. This feature has disappeared. It probably should include the version update example below
Next: Downloading Update
H/W ver: 0.1
S/W ver: 0.0.12
S/W size: 1904731
Update: Yes/No. YES
Update S/W ver: 0.0.13
Update size: 1905200
More file information will be displayed when the OTA-SSU is moved to the 11842 transponder. We are currently working with server carousel TS file playout integration and file naming compatibility. Once this is resolved, the updating transponder frequency will be changed and the automatic updating feature will be reactivated as an user selectable option.
Problem after firmware update!
N0 Network
