Feature Request PIP and swap tuner function | SatelliteGuys.US
stonecold
3,487
Directv La La Land
Basically a add the features the 622/722 have from Dish.
PIP well self explanitory.
Turner swap well it like the tivo change turner function both turner are active and have an active buffer so I can switch between turn one say on USA and turner 2 on SCIFI and flip flop between them with out loosing dvr buffer. on the dish net remotes it was the swap button. Which also allowed you to swap the pip .
I dont in this case of it being a hardware limitation or not but in a 500 dollar reciever with dual tuners I kinda expected this functionality compare to a older recievers (dtivo) and (ultimate tv) being able to do what small function . Also they are features I miss on from all my dual tuner dish boxes.
PIP is not supported in hardware by all of the receivers, so that's probably off the table.
A workaround for swap (or jump) is documented in a FAQ somewhere.
MRV does me no good. Unless they could do it via the sat tuner so a D11 or other standard reciever could view programing from a dvr unit. Like dishcomm but dish net has yet to use any real use of the dish comm system which basically is home plug system.
I don't remember seeing anything saying that something better than DLB was coming. They spent some time developing the single buffer system, making it work better for those desiring DLB.
MRV is a totally different project.
What happened to that? I remember reading that quite a while ago.
yeah i remember reading that too. I also remember reading somewhere that besides the could be tivo for the 2nd half of 09, there would also be a version of the tivo software for the HR series available as an option. I guess I'm loosing it:D
Now I DON'T remember seeing anything like that. :D
Jimbo
CEs for 1/2
Minor Mediashare problem with x02B5 (HR22-100)
