GEOSATpro - Feed Issue | SatelliteGuys.US
GEOSATpro Feed Issue
phantom_76
36
Ontario Canada
Hello Guys im New here and have had a micro Hd for about a mouth and a bit im amazed with this receiver but this is the second Feed that i have came across that you scan it in and go to it and only get a blip of audio every time you in to the channel and no video just black there is a feed on right now on 95w G3c/C Tagged Freebird 1 3883/H/29198 any one else come across this issue a friend of mine scan it in on his Openbox and told me it was a Car Auction for some nice old cars and said it was good picture so is there a issue with the firmware or a bug with the receiver Thanks
Ya forgot to say the HD Symbol is on in the info says sometimes video resoluinon By Source change back to it and the next time it says 576i still with the HD Symbol on each time the Fec is 3/4 DVB-S QPSK
Dont know if it will help with the issue but its the feed is back up right now doing the same thing as lastnight any help on this would be great Thanks
Just got around to checking and it is doing the same here on the micro and my openbox X3, so not just a microHD problem.
My microHD scans it as 3880 V 29198. You might try changing it once. I have it up on my PC setup with 3883 freq though. HD 1920x1080 Good picture for sure.
I just changed Trans info to 3880 still same thing thanks video res is whats getting me some times say By Source and then 576i with the HD Symbol on each time i know its 1080i HD with a symbol rate like that
Just hooked up the S10 and tried and same thing as OP.
Ok this is what i have found so far just hooked up my old sd receiver and it scans in 3884 H 29189 and getting full Audio and have a funkey colors screen thats what my old receiver dose for 1080i feeds so the feed is there its not 4.2.2 feed weird one for sure like this is only the second feed that i have found like this it was on 123w Ku have to keep my eyes open for more and try to find out what type of feed these are its odd Thanks Every One for your replys and Help
This is a DVBS, 4:2:0, 1080i, 39Mbps signal..... WOW! :eek:
No PCR is defined by the encoder. Manually entered the channel into the microHD using VPID as the PCR, but no change.
Made a TS recording for future testing on the modulator / test bench. No idea at this point why the service is not playing.
H264 or MPEG-2 video? The three ALI boxes I own have varying degrees of how good or bad they play H264 streams - the microhd being the best, manhattan great to pretty good and openbox s10 horrible.
Just wondering if this issue has been look at the samething is happen again not seeing any picture just some sound for a few seconds then black 95w G3c 4022 29200 DVB-S QPSK info says video Res Buy Source and say 576i but HD is on display whats up with these type of feeds??? Thanks Cor
Just made another TS recording. It is the same auto show as last time.
The parameters are:
freq:4022, polarity: vertical, Symbol Rate: 29199, FEC 3/4, MPEG2, 4:2:0, 1080i, 29.97fps (NTSC). Once again, the PCR is not defined. 38Meg Video!!! WOW!!!
We will work on this and see why the receiver is choking on this fat signal.
Thanks Brian its odd why it chokes on that but it is what it is hope there is a fix for it ive only ran across this issue 3 times now 1st one didnt think anything of it but there is always glitches along the way Thanks
