FF/RW dispay bar question | SatelliteGuys.US
Bytes2u
19
On the HR20's is there a work around yet to have the fast forward onscreen display bar turn off faster like on the old Tivo boxes. I know you can just hit exit but I had hoped someone found an easier way.
It does not appear on skip backwards, only forward skip and FF.
Not sure if this applies, but there is a setting in the MENU for making the title bar display for only 3 seconds...does that help with your play bar?
And at least the play bar goes away...when I had E* box, the play bar stayed on all the time if you paused the recording. Darn thing burned into my old RPTV. :(
Just hit the exit button while it is in ff mode, that's the only way I know of. It's not so difficult!
Hitting exit isn't that hard but I believe they are looking to turn off the ff progress bar all together & not just have it disappear after ff is complete.
That's what I said.
That's what I was looking for. Guess it can't be done.
Help- Constant Video Loss
To DirecTV or not DirecTV (Many questions)
