Finally, a full-function IR remote solution for the PS3 | SatelliteGuys.US
I thought there was some USB device that enabled IR remotes to work on the PS3?
There is and the article says that there is. It also mentions that those don't do all functions. i would have to see how much this one is. The aded functionality is not all that important.
Can you add an external USB port replicator to one of the two on the PS3? Like you can for PCs?
Some have reported success with hubs but have noted that one or two devices need to go straight into the PS3 not the hub. having said that I have heard similar stories in the PC world.
Disney's Magical Blu-ray Tour Extended Through 2008
Best Buy quitting the 80GB PS3?
