Finding AMC-6??? | SatelliteGuys.US
Finding AMC-6???
JackR
17
I live at Lat 41.5N, Long 72W in Woodstock Ct.
The Satellite due south of me is AMC-6.
Is is possible to get a signal from AMC-6 with my equipment?
Pansat 3500S
Invacom SNH-031
Windgard 76 Antenna
SG-2100 Motorized H-H Motor
I have no problem picking up SBS-6 at Long 74W.
If I use SBS-6 as my true South setting, how do I compensate for the
2 degree differents for true South at Long 72W.
Sure is, someone here sitting in front of their system maybe kind enough to PM you a LIVE channel or Transponder to use..........
If you wanted to use another satellite you would have to USALS over then point the dish........
Always a good idea to have your True south satellite already found and loaded in the receiver before adding a motor........but it can be done!
I am sorry, but I don't understand your reply.
I think you were asking maybe someone to PM me with some basic information that I might need in order to use AMC-6 for my True South location.
Would really appreciate that information however it is available.
Thanks for you reply and time.
Jack
Try using 11839 Vertical with a symbol rate of 25320. This is a data carrier but will register signal and quality for aiming purposes.
Thank you Isat for the information. Will try again in the next few days to get better alignment.
Jack
Building a platform for my dish.
36" dish and NSS 7 Sat
