finding true south | SatelliteGuys.US
finding true south
talktoo264
4
im trying to find true south in jacksonville florida using a sg2100 motor i cant find true south to point at please help me find true south.my lat 30 & long 81
For others to help you, it would be better if you post all your equipment.
Check out the following links below for setting up your dish. Your TS should be around 180+4.5= 184.5 degrees on your compass. You should use a signal meter, along with your receiver to find your first satellite...I would recommend using USALS and move to your closest sat. i.e. 79w degrees. Look for 12182/H/23000 or 11742/V/11110 transponder...
http://sadoun.com/Sat/Installation/HH-mount-installation.htm
http://www.geosatfinder.com/
Your TS should be around 180+4.5= 184.5 degrees on your compass.[\QUOTE]Sorry it should be around 180 + 5.6 = 185.6
I lost 30w!
Gbn
