Fine adjusting Slimline Azimuth | SatelliteGuys.US
gordoinaz
3
I recieived the new slimline dish and was wondering how to fine adjust the azimuth. The slimline dither is a finethread adjustment screw and isn't unlocking like the old 5 lnb dish.
Has anyone else had any luck setting up a slimline?
Thanks in advance!
Gordo
It's just like adjusting the elevation on the AT9. Do a coarse peak then detune by the specific amount of turns, note the level and find the exact same level on the other side while counting the amount of turns to get there. Divide the amount of turns in half and back up by that much. It has the same result as the pull pin on the original mount. Read the manual that came with the antenna, it has the procedure for both types of mounts. There is a training video somewhere that covers the new mount.
Rick
1 sub....2 houses
HELP! RCA DVR-120. I'm a total newb.
