Looking for some help in fine tuning my setup.
DISH 500 with 2 DP 7200's.
Currently getting high 60's on 110, and 50's on 119 on the combined screen display.
As I understand based on my zip, my settings should should be: AZ-242, EL-31, SK-129.
If I understand some of what I have read on here, in order to try and increase my signal strength I need to do the following:
Disconnect one of the s-21 switches and install a connector, check my 119 signal and then slowly adjust the elevation to see if the signal strength increases. In order to increase my 119 strength, do I need to raise or lower my elevation?
Once I'm satisfied with 119, re-install the s-21 switch, run the check switch, and then re-do the procedure for 110?
Is this about right??
Should I be checking for signal strength on individual transponders, or just using the strength meter for the 110, 119 sat?
Thanks in advance.
Thanks in advance.
